Button dimming (8-bit value) - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Button dimming (8-bit value) (/showthread.php?tid=1334) |
Button dimming (8-bit value) - Jayce - 09.04.2018 Hey, I'm trying to dim a RGB led strip using nothing but a button and logic machine. Basically what I need is to get 8-bit value from a button so that when I hold the button, value toggles between going up and down. Is this possible? If not, what is the best way to control dimming dali lights using a simple button (or two, one up one down), preferably without using any scripts. RE: Button dimming (8-bit value) - Erwin van der Zwart - 09.04.2018 Hi, Check this article: https://forum.logicmachine.net/showthread.php?tid=275&pid=1238#pid1238 BR, Erwin RE: Button dimming (8-bit value) - Jayce - 10.04.2018 (09.04.2018, 15:56)Erwin van der Zwart Wrote: Hi, Thank you very much for help, bear in mind I'm a beginner though. I tried what you posted about 3bit dimming object, got to a point where i'm supposed to set value after _ in longpresstime_xx. I can't seem to find longpresstime_xx anywhere in the javascript that I pasted in custom javascript. Could you help me please? EDIT: Nevermind, I figured it out but now I'm having problems with linking the dim UP and DOWN buttons to a real physical buttons I have set up and to the RGB led strip. RE: Button dimming (8-bit value) - Erwin van der Zwart - 10.04.2018 Hi, You could try something like this: Code: addressbyteoutput = '32/1/1'
stepsize = 10
value = event.getvalue()
current = grp.getvalue(addressbyteoutput)
if value < 8 then
if current <= stepsize then
output = 0
if current ~= output then
grp.write(addressbyteoutput, output)
output = current - stepsize
elseif value > 8 then
if current >= (100 - stepsize) then
output = 100
output = current + stepsize
endErwin RE: Button dimming (8-bit value) - Jayce - 10.04.2018 Hello, Excuse me again, how do I try that? Where should I put the script and what should the addressbyteoutput address be? As I said I'm a beginner, if you have time, could you please walk me through this? Right now I'm in a state where I have done all from the link you sent me, I have two buttons in my visualization, one UP and one DOWN, both have longpresstime set to 10 (1 second). Also, I have 1/1/199, which is my LED strip that I scanned from dali section in LM, I can control the strip with 1 byte unsigned integer. RE: Button dimming (8-bit value) - Erwin van der Zwart - 10.04.2018 Hi, Just create a 4 bit object that is connected to your physical KNX pushbutton (dimming object), add the script as event based to this object, create a byte SCALE object for your RGB DALI unit and set this object (1/1/199) as addressbyteoutput. Then it should work.. But do i understand it correct from your last post that you use LM dali interface? If that is the case you should be able to use the commands from http://openrb.com/docs/dali.htm and then you should not be needing this script.. BR, Erwin RE: Button dimming (8-bit value) - Jayce - 11.04.2018 Yes, I'm using Logic Machines DALI Gateway, sorry for not mentioning earlier. RE: Button dimming (8-bit value) - Jayce - 13.04.2018 Sorry to bother again but would you mind walking me through the method with dali commands you said? Also, what I mean by dimming the RGB strip with pushbutton is that when I hold the button the value goes gradually up. Not sure if I mention this either. RE: Button dimming (8-bit value) - Erwin van der Zwart - 13.04.2018 Hi, How are you going to config the pushbutton? As 4 bit dimming? BR, Erwin RE: Button dimming (8-bit value) - Jayce - 16.04.2018 Hello, Yes, I have set the pushbutton so it is 1bit switching and 3bit dimming. That makes 4bit. RE: Button dimming (8-bit value) - admin - 16.04.2018 We plan to implement 4-bit dimming in DALI gateway plugin soon. RE: Button dimming (8-bit value) - Bobby - 16.04.2018 Is it possible to make a single switch: 1 short push , toggle on / off (remember last state if dimmed) 1 long push, dim up and for next long push, dim down and so on? RE: Button dimming (8-bit value) - Jayce - 16.04.2018 It doesn't have to be 4bit for me, is there any way to make it work so a pushbutton controls dimming of a dali light when using LMs dali gateway? All I'd like it to do is to dim up/down while I hold the button. Thank you. RE: Button dimming (8-bit value) - Daniel - 16.04.2018 Hi You can do it as fallow. Create 4 bit dim object 3.007 and let all parameters as default. Create event based script on this object and use this script. Code: step = 10 --dimming step
stepTime = 0.5 --- dimming interval
ballastAddress = 1
gatewayID='internal'
valuein = event.getvalue()
require('user.dali')
res, err = dalicmd(gatewayID, 'queryactual', { addrtype = 'short', address = ballastAddress })
-- read ok
if res then
status = res:byte()
while( valuein==11 ) do
status = status + step
if (status >254) then
dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress, value = 254})
dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress, value = status})
valuein = grp.getvalue(event.dst)
os.sleep(stepTime)
while( valuein==3 ) do
status = status - step
if (status <0) then
dalicmd(gatewayID, 'arc', { addrtype = 'short', address = ballastAddress, value = 0})
os.sleep(stepTime)
endModify parameters Add this object on to visu and test. Should work : ![]() Dalli arc is logarithmic curve so you will have slower dim on low values and fast on bigger. BR RE: Button dimming (8-bit value) - Jayce - 17.04.2018 Works very well, thank you very much. RE: Button dimming (8-bit value) - alexll - 09.11.2021 (10.04.2018, 10:50)Erwin van der Zwart Wrote: Hi, Hello. I'm trying this event script with a 4 bit object from KNX, but it only dimms with many "long-pressed" actions, and not mantaining the KNX button switch. Is it the problem on the KNX side or script's? RE: Button dimming (8-bit value) - admin - 09.11.2021 Why do you need a script if this switch supports "dimming steps" mode? RE: Button dimming (8-bit value) - alexll - 09.11.2021 (09.11.2021, 09:09)admin Wrote: Why do you need a script if this switch supports "dimming steps" mode? Is that the solution? I've never used that option. I'm going to try that. Thank you! Edit: Confirmed. It works using "dimming steps" option + your 4 bit object dimming script. It has to be done like that because I needed to dim some Philips Hue LED strips from a KNX single button. |
