LM network communication - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: LM network communication (/showthread.php?tid=1339) |
LM network communication - David - 16.04.2018 Hi, I've some questions about communicating 4 Logicmachine 5 Lite. Each of these Logicmachine is placed on a KNX installation and LM communicate each other via ethernet. Is it possible to configurate LM as KNX IP Router? Which is the best way to be able to see all the KNX data from any of the LM? Do I need to set a BACNET configuration to communicate between LM? Best regards. RE: LM network communication - Daniel - 16.04.2018 Hi You don't have to do anything. They talk to each other out of the box via KNX multicast as long you didn't change anything. You can add filter table to limit amount of telegrams. BR RE: LM network communication - CHOUAIBOU - 16.04.2018 (16.04.2018, 16:53)David Wrote: Hi, Hi David, The inconvenient is that each LM device will be saturated with knx objects from others LM ( if you use filter tables, you are not going to get your use case). B.R RE: LM network communication - David - 17.04.2018 Thank you very much @Daniel. and @CHOUAIBOU ! B.R. |
