SOURCE ADDRESS - Printable Version
+--- Thread: SOURCE ADDRESS (/showthread.php?tid=1344)
SOURCE ADDRESS - Angeles - 19.04.2018
Hi:
I need to know the source address from an event.
I need it because it depends on where the event comes from, I will perform one task or another
it would be something like reading the result the value of the event, but in this case it would be from whom
value = event.getaddress()!!
RE: SOURCE ADDRESS - Daniel - 19.04.2018
value = event.src log(value)
RE: SOURCE ADDRESS - Angeles - 19.04.2018
The result is 'local' I need knx source address....
The result is local when you send telegram from LM. Send telegram from KNX and check again.
(19.04.2018, 14:08)Daniel. Wrote: The result is local when you send telegram from LM. Send telegram from KNX and check again.
Sorry , it's perfect.
