not working script with timer - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: not working script with timer (/showthread.php?tid=1354) |
not working script with timer - AlexLV - 24.04.2018 Hello, please help me find error. Task - when light in bathroom is off - i want swith on ventilation for 10 minutes. Found timer script at forum, but something is wrong in my script. Group 0/2/1 is 1 when light is Off and 0/2/1 is 0 when light is On. 6/0/1 and 6/0/2 switch On/Off ventilator. When light is off, ventilator starting but not switching off... May be problem is that 0/2/1 is always =1 till light is Off?? -- group address or name Vanna light on/off addr = '0/2/1' -- find required object obj = grp.find(addr) -- object exists and current state is "on" if obj and obj.data then -- I think my problem is here but how to change correctly? -- delta is in seconds delta = os.time() - obj.updatetime grp.write('6/0/1', 1) grp.write('6/0/2', 1) -- switch off when timer expires if delta >= 10 * 60 then log(os.time()) log(delta) log(obj.updatetime) grp.write('6/0/1', 0) grp.write('6/0/2', 0) end end RE: not working script with timer - admin - 25.04.2018 If your light status object is inverse you need to add not: Code: if obj and not obj.data thenRE: not working script with timer - AlexLV - 25.04.2018 I added inverse, but anyway something is not correct - timer not working.When light is off, ventilator starting, but not stopping...I put less time, 1 minute, but the same.. What could be wrong? RE: not working script with timer - admin - 25.04.2018 Is it a resident or a scheduled script? RE: not working script with timer - AlexLV - 25.04.2018 sorry it is event-based... It shoudbe resident? RE: not working script with timer - Daniel - 25.04.2018 Hi Do it like that. Resident script with interval as you want. This will decide how fast it will switch on and off from receiving false Code: addr = '0/2/1'
addrVent1 = '6/0/1'
addrVent2 = '6/0/2'
timer = 600
if obj and not obj.data and delta < timer then
grp.checkwrite(addrVent1, true)
grp.checkwrite(addrVent2, true)
elseif obj and not obj.data and delta >= timer then
grp.checkwrite(addrVent1, false)
grp.checkwrite(addrVent2, false)
endRE: not working script with timer - AlexLV - 25.04.2018 Daniel, BIG THANKS! All is working as needed! |
