KWH Monitoring - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: KWH Monitoring (/showthread.php?tid=1405) |
KWH Monitoring - Sjef de Laat - 20.05.2018 Hello! For kwh and Gas to monitor in the LM or HL what is the best and easiest way for that? On the internet there are cables from P1 to USB, do they work on the LM or HL? The USB I would like to use for Z-wave there is no hub between for sure, or is that possible? I would like to have a solution here that is not too difficult for me, maybe at one time on the KNX bus like the P1G2 can, but maybe there are better and easier solutions. Sjef RE: KWH Monitoring - equalizer - 24.05.2018 Some USB cables like that show up as a serial device. If you know the protocol they are using on serial you can talk to them if the serial chipset they are using is also supported. So definitely maybe lol. First thing is to plus you usb device in to the USB port and see if it shows up as a serial device. |
