equivalent to "window.onload" - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: equivalent to "window.onload" (/showthread.php?tid=1427) |
equivalent to "window.onload" - SigmaTec - 06.06.2018 Hi all, I'm looking for this method : how to detect that a page (whatever this page, not a particular page) has just been loaded, with an equivalent of "window.onload" in javascript? Someone knows the solution (Erwin for example ;-))? Have a good day ! RE: equivalent to "window.onload" - admin - 06.06.2018 Can you explain what are you trying to achieve? RE: equivalent to "window.onload" - SigmaTec - 06.06.2018 Hi , here is my need: with custom JS, change the value of a group [JS grp.write()] each time a page of the visualization is accessed by a user. Note: that's why I was referring to the JS instruction "window.onload". It is necessary for this: 1. I detect the Id of the activated page 2. I write in a value in a group Hoping you have been more accurate ... RE: equivalent to "window.onload" - Erwin van der Zwart - 06.06.2018 Hi, You can do that like this: Code: $(function(){
$('body').on('showplan', function(e, id) {
grp.write('1/1/1', id);
});Erwin RE: equivalent to "window.onload" - DGrandes - 24.06.2021 Hi, I want to write an object before I close visualization window. I think the function is "window.onbeforeunload" but witch is the equivalent? Is there any page to see all javascript function in Logic Machine? Thanks!! RE: equivalent to "window.onload" - admin - 25.06.2021 The visualization runs in a browser not in LM. The supported functions is what the browser supports. This can be used to switch an object off when the visualization page is exited: Code: window.onbeforeunload = function() {
if ($('body').hasClass('usermode')) {
grp.write('32/2/21', false);
};RE: equivalent to "window.onload" - DGrandes - 30.06.2021 (25.06.2021, 11:48)admin Wrote: The visualization runs in a browser not in LM. The supported functions is what the browser supports. Thanks!! It worsk perfectly. I have another question, I want to know when a visualization is opened and I put this code: Code: grp.write('32/1/152', true);
grp.write('32/1/152', false);
};But doesn´t work. What is wrong? Thanks! RE: equivalent to "window.onload" - admin - 30.06.2021 You have to wait for the WebSocket connection to be established. Use this: Code: if (typeof localbus === 'object') {
$(localbus).on('connect', function() {
