Filtering info from loop - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Filtering info from loop (/showthread.php?tid=1498) |
Filtering info from loop - FatMax - 24.07.2018 I'm trying to do scheduled scan of a tag weekly to ultimately send me an email with a report if something is wrong. However, I'm seeing that some info is left out. Logically I can see why, but I'm having some trouble fixing the logic for myself to see the solution... First edition of script: Code: ecgFail = grp.tag('ecgFailure')
total = 0
for index, value in ipairs(ecgFail) do
if value.data == true then
total = total + 1
name = value.name
log('Found '..total..' ECG(s) with failure. Id´s: '..name)Output in the log: Code: * string: Found 2 ECG(s) with failure. Id´s: L5 - DALI ECG 3, Failure StatusAs you can see I'm missing the name of the second ECG with failure. Any suggestions? RE: Filtering info from loop - Daniel - 25.07.2018 The log for individual errors should be in the loop. RE: Filtering info from loop - FatMax - 25.07.2018 (25.07.2018, 14:08)Daniel. Wrote: The log for individual errors should be in the loop. Yeah, I figured that might be the solution. However, the end goal is to get them all neatly listed in an email. Wouldn't that just do the count wrong then? I understand I don't need the count, but its fun to learn something new in the process
RE: Filtering info from loop - Daniel - 26.07.2018 Hi Try something like that Code: ecgFail = grp.tag('ecgFailure')
total = 0
buffer = { 'Name' }
total = total + 1
name = value.name
buffer[ #buffer + 1 ] = table.concat({
name,
csv = string.char(0xEF, 0xBB, 0xBF) .. table.concat(buffer, '\r\n')
res, err = mailattach('someone@example.com', 'Report', 'CSV file attached', 'report.csv', csv, 'text/csv')
log('Found '..total..' ECG(s) with failure. Id´s: '..name)Use email function from here https://forum.logicmachine.net/showthread.php?tid=394&pid=1994#pid1994 BR |
