PoE Doubts - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: PoE Doubts (/showthread.php?tid=1510) |
PoE Doubts - josep - 01.08.2018 Hi, I have several questions about PoE power, I usually use a PoE injector from Ubiquiti reference POE-24-12W-G, in the specifications it says that it uses pins 4 and 5 as positive and (3,6) and ( 7,8) as negative, this injector is a passive PoE injector? If so, what do I have to look for when buying a PoE injector to work with the LM? I would also like to know what function have the jumpers that are next to the 24V input. Thank you very much. RE: PoE Doubts - admin - 02.08.2018 Hi, see this post: https://forum.logicmachine.net/showthread.php?tid=289&pid=1322#pid1322 You probably need POE-24-12W (not the gigabit model). Jumpers can be used to disable PoE. By default they should be in PoE enabled position. |
