Backup is invalid - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Backup is invalid (/showthread.php?tid=1543) |
Backup is invalid - Carlos Padilla - 19.08.2018 Hi, this is to tell you that I have problems loading the backup of a logic machine 5 lite power to another logic machine 5 lite power. When trying to do it, it tells me that the backup is invalid. Check the version in which I try to load the backup and it is 20170620 with Linux kernel version 4.4.73, while in which I work and from where I get the backup version is 20180523 with Linux kernel version 4.4.135. That same Backup, I charge it to another logic machine that has the same version and if it accepts it. I already deleted the cache as I read in a forum, but nothing. I hope your collaboration, since I do not know how to solve this problem. Thank you for your cooperation. RE: Backup is invalid - admin - 20.08.2018 Backups from new FW versions might not work on older FWs. We are going to publish pre-release firmwares this week so you can try upgrading older LM that you have. |
