Problems with Modbus in Logic Machine with Firmware 20180523 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Problems with Modbus in Logic Machine with Firmware 20180523 (/showthread.php?tid=1546) |
Problems with Modbus in Logic Machine with Firmware 20180523 - Carlos Padilla - 21.08.2018 Good, I have a logic machine with 20180523 Firmware and although the objects are well mapped and the settings are correct, I can not get the values or the changes of the Modbus registers, but I use a logic machine with a firmware 20170620 if I can obtain the values of the records and show the changes in the part of objects. It should be noted that both have the same type of Modbus configurations and the same profile, but only in the current version does it work for me. On the other hand if I go to the part of the registry errors I get the following image: Thank you for your cooperation and I will be attentive to your answers. RE: Problems with Modbus in Logic Machine with Firmware 20180523 - admin - 21.08.2018 Please send LM backup to us via email RE: Problems with Modbus in Logic Machine with Firmware 20180523 - Carlos Padilla - 23.08.2018 Ready, with the new Firmware (20180822) This problem has already been solved. A question I have a record that is type int8, this data is not supported for the JSON, because I got an error when trying to read the computer, but once I changed it to int16, I could read it, even though the computer manufacturer it tells me that the record is of type int8. RE: Problems with Modbus in Logic Machine with Firmware 20180523 - Daniel - 23.08.2018 Modbus register is always 2 byte so even if they just use 1 byte they have to use 2. |
