SNMP protocol in Logic Machine - Printable Version +- Logic Machine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: SNMP protocol in Logic Machine (/showthread.php?tid=1573) |
RE: SNMP protocol in Logic Machine - AlexLV - 13.04.2020 admin, as always all working super!! Big thanks for advices and help! Alex RE: SNMP protocol in Logic Machine - AlexLV - 14.04.2020 Hi, As we can now receive bytes in and out 0ver SNMP, how correctly calculate bit/per second from received data? I found very easy calculation method: We can calculate the throughput of an interface using this technique: take a sample of the total bytes-in, wait 60 seconds and take another sample bytes-in total. TotalByteIn [t = 0s] is total bytes-in after 0 seconds TotalByteIn [t = 60s] is total bytes-in after 60 second The average throughput in this time interval is calculated using this formula (the value is Bps) (TotalByteIn [t = 60s] - TotalByteIn [t = 0s]) / 60 = Throughput So 60 here - time in seconds, delay between request of SNMP information. Question - how easier store previous data to calculate BPS (I need received value - last one or previous, or other variant - now and next value after 60 seconds). I tried resident script with time 0, not working but strange - in log showing TX1 and TX2 the same values, but BPS different (in my case I receiving SNMP data every 10 seconds).. TX1 = grp.getvalue('38/5/22') log('TX1', TX1) os.sleep(10) TX2 = grp.getvalue('38/5/22') log('TX2', TX2) BPS = (TX2-TX1)/10 log('BPS', BPS) How better calculate BPS?? BR, Alex RE: SNMP protocol in Logic Machine - admin - 15.04.2020 Use storage to store previous object value. See these examples: https://forum.logicmachine.net/showthread.php?tid=2552&pid=16316#pid16316 https://forum.logicmachine.net/showthread.php?tid=347&pid=1707#pid1707 RE: SNMP protocol in Logic Machine - mischa - 08.12.2020 (04.09.2018, 09:17)AEK Wrote: Hi, as I know, traps are still not supported Hi, I have installed these pakkages, but when running the script it says: Resident script:1: module 'snmp' not found: no field package.preload['snmp'] no file './snmp' no file 'Library snmp' no file 'Library snmp' no file 'Library snmp.so' stack traceback: [C]: in function 'require What am I missing? RE: SNMP protocol in Logic Machine - admin - 09.12.2020 Which firmware are you using? Have you tried the latest packages (https://dl.openrb.com/lm-20-imx6/pkg/)? RE: SNMP protocol in Logic Machine - mischa - 11.12.2020 (09.12.2020, 07:07)admin Wrote: Which firmware are you using? Have you tried the latest packages (https://dl.openrb.com/lm-20-imx6/pkg/)?These versions runs error on install. Running: HW: Wiser for KNX (i.MX6) SW: 2.5.1 RE: SNMP protocol in Logic Machine - khalil - 11.03.2021 (09.12.2020, 07:07)admin Wrote: Which firmware are you using? Have you tried the latest packages (https://dl.openrb.com/lm-20-imx6/pkg/)? hello admin I have LM Lite + Ext SW 20200727 when I try to upload the packages I got : RE: SNMP protocol in Logic Machine - admin - 11.03.2021 You have to install these packages through System config > System > Packages > Add (+) button RE: SNMP protocol in Logic Machine - khalil - 11.03.2021 (11.03.2021, 13:15)admin Wrote: You have to install these packages through System config > System > Packages > Add (+) button hello admin thank you for your response I upload the packages I use the walk through SNMP code but I get the following error: User script:40: attempt to index global 'snmp' (a nil value) stack traceback: User script:40: in main chunk RE: SNMP protocol in Logic Machine - admin - 11.03.2021 Add require('snmp') at the beginning of your script. RE: SNMP protocol in Logic Machine - khalil - 11.03.2021 (11.03.2021, 13:34)admin Wrote: Add require('snmp') at the beginning of your script. Thank you admin for your response I got a time out in the log what should I check * arg: 1 * nil * arg: 2 * string: walk failed: snmp: timeout RE: SNMP protocol in Logic Machine - admin - 11.03.2021 This means that LM cannot reach the SNMP device on the network. Check that IP address is correct. RE: SNMP protocol in Logic Machine - Black_Angel666 - 28.10.2021 Good day! Tell me, is it possible to transfer data from the KNX to the SNMP by means of LM so that another client can monitor the data? RE: SNMP protocol in Logic Machine - Daniel - 29.10.2021 See this https://forum.logicmachine.net/showthread.php?tid=2371&pid=14905#pid14905 RE: SNMP protocol in Logic Machine - khalil - 18.09.2022 Hello I added the libnetsnmp and luasnmp packages Please see attached image. I used the old HL ,V2.7.0 but When I run my script I got the following errors: Resident script:3: module 'snmp' not found: no field package.preload['snmp'] no file './snmp' no file 'Library snmp' no file 'Library snmp' no file 'Library snmp.so' stack traceback: [C]: in function 'require' RE: SNMP protocol in Logic Machine - Daniel - 19.09.2022 Go to System Config - System - Packages and press + to install. RE: SNMP protocol in Logic Machine - khalil - 19.09.2022 (19.09.2022, 07:33)Daniel Wrote: Go to System Config - System - Packages and press + to install. Hello Daniel I have the old Schneider electric HomeLynk but I am using FM-V 2.7.0. I cant find any packages installation option! RE: SNMP protocol in Logic Machine - Daniel - 19.09.2022 SE does not have this option. Next time buy LM ![]() In upcoming fw snmp libraries will be added. Just wait for a while. RE: SNMP protocol in Logic Machine - khalil - 19.09.2022 (19.09.2022, 10:59)Daniel Wrote: SE does not have this option. Next time buy LM Great. For Both SE and LM? RE: SNMP protocol in Logic Machine - admin - 19.09.2022 Yes, for both. |
