Modbus and RS485 communications - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Modbus and RS485 communications (/showthread.php?tid=1575) |
Modbus and RS485 communications - Dan22 - 04.09.2018 Hello, in the past I used LM only as the gateway to KNX + visualization. I used basic scripts in LUA. Now I get to the project, where MODBUS communication and RS485 communication is needed. I went through the forum and still do not know how to do it. Are there any examples of crypts for RS485 communication and Modbus communication or manual? The Modbus-TCP communication will be used to control the massage bathtub. RS485 communication will be used to control the fireplace. I have communication protocols for the device. I have LM5 IO V2 available. Thank you for your help. RE: Modbus and RS485 communications - admin - 05.09.2018 The easiest way to interface modbus devices is to use profiles/built-in mapper: http://openrb.com/docs/modbus.htm Serial communication library is also built-in: http://openrb.com/docs/serial.htm There's also an example of Denver e-Ribbon Fire control: http://openrb.com/logicmachine-as-gateway-to-denver-e-ribbon-fire |
