Slider / direct input size - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Slider / direct input size (/showthread.php?tid=1584) |
Slider / direct input size - Kai-Roger - 11.09.2018 Hi. Is it possible to change size of direct input altso? I se from a thread that the following code resizes the slider: .item-control-single .control-slider { transform: scale(1.5); transform-origin: 0 0; } I altso wonder if resizing functionality for these will be possible to add in the "plan editor" in the future for us who are not so deeply involved in scripting ![]() BR RE: Slider / direct input size - admin - 12.09.2018 Use this CSS for direct input: Code: .item-control-single .control-spinner {
}RE: Slider / direct input size - Kai-Roger - 12.09.2018 Thanks
RE: Slider / direct input size - Kai-Roger - 12.09.2018 Is there a list of the names of these controlls? Now i need the toggle to resize, but when i write "toggle" in CSS nothing happens. .item-control-single .control-toogle { transform: scale(1.6); transform-origin: 0 0; } RE: Slider / direct input size - admin - 12.09.2018 Right click on the control and select "inspect element". There you can find class names for different controls. RE: Slider / direct input size - Kai-Roger - 12.09.2018 Thanks. That was easy ![]() it's only pity that the resize don't get reflectet when in editor mode, but thats probably somthing we just have to live with?
RE: Slider / direct input size - Daniel - 12.09.2018 Custom CSS and Custom Java Script is only applied to visu RE: Slider / direct input size - Kai-Roger - 12.09.2018 Yes i am aware of that. I just have to make space around the controls before saving, or else it wil be like in the picture attached. I was just hoping for a more subtle approach to resize the controlls ![]() I don't mean to be demanding. After all i am very happy with the LM5, and if this is how i have to do to resize the controlls, i can live with that. |
