Move up/down widgets - Vis.structure - Printable Version
+--- Thread: Move up/down widgets - Vis.structure (/showthread.php?tid=1586)
Move up/down widgets - Vis.structure - Kai-Roger - 12.09.2018
Hi.
Is it possible to move the widgets and layouts under "Layouts / Widgets" up and down in the list like in the "Levels / Plans"?
RE: Move up/down widgets - Vis.structure - admin - 12.09.2018
No, but I suppose it would make more sense to sort them by name instead of creation order
RE: Move up/down widgets - Vis.structure - Kai-Roger - 12.09.2018
By name would be an acceptable solution  Shy Is that possible?
Yes, RC2 will have this implemented.
Fantastic Smile This will make my widget list look clean and it will be easy to work with  Cool
