Erase Object Name - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Erase Object Name (/showthread.php?tid=1589) |
Erase Object Name - Neol - 14.09.2018 I would like to delete the "Object Name" of several Object with a script. Any idea? thanks RE: Erase Object Name - admin - 14.09.2018 Can you explain the use case for that? RE: Erase Object Name - Neol - 14.09.2018 I created an interface that helps me to set up my script and I want to erase it at the end without breaking my script RE: Erase Object Name - admin - 14.09.2018 You can remove objects via grp.delete function. But if you need something temporary you should use storage instead of objects. RE: Erase Object Name - Neol - 18.09.2018 (14.09.2018, 11:30)admin Wrote: You can remove objects via grp.delete function. But if you need something temporary you should use storage instead of objects. Thank you, but this method delete the object and i just want to delete the object name. RE: Erase Object Name - admin - 19.09.2018 Then the only way is via a db query (reload web interface for changes to appear): Code: id = buslib.encodega('1/1/1')
db:update('objects', { name = db.null }, { id = id })RE: Erase Object Name - Neol - 19.09.2018 it works. thank you! |
