Backup and restore issue - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Backup and restore issue (/showthread.php?tid=1593) |
Backup and restore issue - baggins - 15.09.2018 A couple of days ago we had a power cut and after the power came back on I noticed that in one of my LM4 (I have two in my home) there was no data anymore in the trends. As as take daily backups, I took the backup of the previous day and did a restore. After the restore there were still no trend data and I noticed that some GA and a script that I added some time ago were also missing. I looked in the backup at the current.db and I could see that these GA and the script were actually there. At first I thought I made a mistake, so I did the following:
After the restore, the situation was the same as previously: no GA nor script, no trend data. I then restored the backup that I took manually: same result: the GA and the script were gone and the trend info that was acquired the previous day was also gone! I did a restore of the scripts backup to get the script back which worked. New trend data is acquired. Any idea what is going on here? RE: Backup and restore issue - Erwin van der Zwart - 15.09.2018 Hi, It sounds like your SD card is flipped to read only. You can test this by creating a new object, sync and reboot. If the object is not there anymore after the reboot there is nothing else you can do then replacing the SD card. BR, Erwin RE: Backup and restore issue - baggins - 15.09.2018 (15.09.2018, 09:07)Erwin van der Zwart Wrote: Hi, Hi Erwin, I found this to replace the SD card: http://openrb.com/reflash-logicmachine3-and-streaming-player-software/ I take it that this also applies to LM4? If I understand correctly, I can take out the existing SD card, make a backup of it and the restore that image on the new SD card? When the LM4 is up and running I can then restore the latest complete backup I have (the one from before the power cut)? Sorry for these questions but I have not done this before and I don't want to screw up my system... BR RE: Backup and restore issue - Erwin van der Zwart - 15.09.2018 Hi, Yes i think that should work, sometimes the content on the SD is corrupt but your card is flipped to read-only so i think the content is not damaged. You should be able to flash it over with USBIT, but i think it will hold the data from the last time it could save to the SD so afterwards you need to reload your latest backup. BR, Erwin RE: Backup and restore issue - toujour - 14.02.2020 Hi Erwin, Can I read an SD to extract the configuration ? I haven't the backup so I can't restore by it. BR, Alberto RE: Backup and restore issue - Daniel - 14.02.2020 In Usb image tool you can make a backup of that card and you can restore it on new. As long the card is not corrupted only in read only mode it will work. RE: Backup and restore issue - HannPark - 22.10.2021 Hi, I know this Thread is old and maybe its closed, but I have the same issue with a Homelynk LS100100 and I tried to reflash and it didnt work, I can't access the graphical view, even hard reset it by the back button, no one knows the ip address, and when i turn on it, stays On like 15 minutes and after that it shuts down... I really don't know what to do about it.... hope somebody can help me.. RE: Backup and restore issue - admin - 25.10.2021 Start by replacing the micro SD card and using recovery firmware. Then you can upload normal firmware and the device will have the default IP address: 192.168.0.10 |
