lost scripts and changes in the visualization - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: lost scripts and changes in the visualization (/showthread.php?tid=1637) |
lost scripts and changes in the visualization - chrigi - 09.10.2018 recently i lost previously saved changes in several scripts, in the user library as well as changes in several pages in the visualization over the past few weeks. it is as if someone would restore old versions, while i am working on the scripts. moreover, if i restore the most recent backup they are not the most recent ones ! i can change something, make a backup and restore and the changes are lost ! it started after i had to hard reset the LM about 5 weeks ago (log). for the rest, it works normally. any idea ? i copied some of the scripts into textfiles to restore them manually... any ideas ? thanks, christian LM5 20170106 lost scripts and changes in the visualization - chrigi - 09.10.2018 [attachment=1047]hi recently i lost previously saved changes in several scripts, in the user library as well as changes in several pages in the visualization over the past few weeks. it is as if someone would restore old versions, while i am working on the scripts. moreover, if i restore the most recent backup they are not the most recent ones ! i can change something, make a backup and restore and the changes are lost ! it started after i had to hard reset the LM about 5 weeks ago (log). for the rest, it works normally. any idea ? i copied some of the scripts into textfiles to restore them manually... any ideas ? thanks, christian LM5 20170106 RE: lost scripts and changes in the visualization - admin - 09.10.2018 Looks like microSD card in your LM became read-only. You need to replace it with a new one an run recovery procedure. See more info here: http://openrb.com/reflash-logicmachine3-and-streaming-player-software/ |
