Difference between PMC and DW1 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: Difference between PMC and DW1 (/showthread.php?tid=1648) |
Difference between PMC and DW1 - Kai-Roger - 12.10.2018 Hi. LM5 PMC have a 320mA Choke LM5 DW1 have DALI and 1-Wire. Is that all the difference between these 2 models? I can't see a USB port on the picture of the DW1, but it it says in the papers that there is a USB port somewhere. Is that correct? BR Kai-Roger RE: Difference between PMC and DW1 - edgars - 12.10.2018 Hi Kai! right, thats the only differences. Both have USB. The concept of LM5 is to use LM5 Lite as a base board (on all devices the same) + add different extensions like Choke or 2xDali/2x1Wire or Reactors. And Choke can do actually more than 320mA, it should be close to what you supply the device with, but not more than 750mA. RE: Difference between PMC and DW1 - Kai-Roger - 12.10.2018 Good information ![]() But with that in mind, i do have one followup question. Why do you say that the Choke only supports 320mA, when it can handle up to 750mA? |
