Script restart after powerloss: ERWIN - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Script restart after powerloss: ERWIN (/showthread.php?tid=1652) |
Script restart after powerloss: ERWIN - SnMa - 12.10.2018 Hello. I have a project where vi run some scripts on a LM. The problem is that when we experience a power loss or do a reboot on the LM the scrips do not start up automatically. Is there a need for a boot script, and is there an example on how to make this available? Regard Snorre Malvik, Oslo RE: Script restart after powerloss: ERWIN - Daniel - 12.10.2018 Hi It depend of type of the script, event will run only if new telegram is received. Resident and Scheduled will run as setup while device will boot up. If you need to run something on boot up then use init script. BR Daniel RE: Script restart after powerloss: ERWIN - adigornik - 14.10.2018 Hello Daniel Let me ask you in a different way. How should I write this script to work after recovering the voltage ? require('custom.fbeditor20.Comparator') Input_1 = event.getvalue() Input_2 = 5000 out, out_not = fbe_less(Input_1, Input_2, 'fb__Bad___lys_over_speil_blokering_kanal_1__fbe_less__id') if out_not ~= nil then grp.write('5/1/1', out_not) end Best Regards adigornik RE: Script restart after powerloss: ERWIN - Erwin van der Zwart - 14.10.2018 Hi, You make things more complex then needed.. On the (event) object settings you can enable “Read during startup” Make sure the read flag is enabled in the ETS for this object. When the controller reboots it will send a read request and the object will get the correct value from the installation and the event script will be executed and the output result should be as wanted. BR, Erwin RE: Script restart after powerloss: ERWIN - adigornik - 15.10.2018 (14.10.2018, 17:37)Erwin van der Zwart Wrote: Hi, Hi Erwin You mean *Execute on group read:* ? Because I did not find anything that is called “Read during startup” How can I do it less complicated ? BR Adam RE: Script restart after powerloss: ERWIN - Daniel - 15.10.2018 He means this Read during start-up |
