Best way to parse a txt table - Printable Version
+--- Thread: Best way to parse a txt table (/showthread.php?tid=1663)
Best way to parse a txt table - gtsamis - 19.10.2018
I have a near by weather station that publish it's data as a txt table. http://grhost.info/kastelokampos/downld02.txt
I would like to get the only the last line of the table in order to use it in my project.
Currently i am using sting.sub (total length - 205 which is the line length) to get the last line and then again string.sub to get each value.
I am sure there must be a more delicate/robust solution but i am stuck so any help would be appreciated.
Thank you in advance
George
RE: Best way to parse a txt table - admin - 22.10.2018
Use this code to split last line data into a table:
data = ... -- get remote data lines = data:split('\n') line = lines[ #lines - 1 ] -- last line line = line:gsub('%s+', ' ') -- remove multiple spaces line = line:trim() line = line:split(' ') -- convert to table log(line)
RE: Best way to parse a txt table - gtsamis - 22.10.2018
(22.10.2018, 06:21)admin Wrote: Use this code to split last line data into a table:
Nice and clean, thank you!  Smile
