ETS do scan but did not see LM5RIOE Individual Address - Printable Version
+--- Thread: ETS do scan but did not see LM5RIOE Individual Address (/showthread.php?tid=1669)
ETS do scan but did not see LM5RIOE Individual Address - Triet Phan - 23.10.2018
Dear colleagues,
I am doing configure LM5RIOE, it is assigned individual address as 1.1.10 , i used USB interface for doing configure for KNX system but when i create a group address on KNX TP system and export esf file to import into LM5RIOE but it looks like it does not work together with KNX TP system. is there anyone can show me how can i check what problem for LM5RIOE ? other devices in KNX system still work together except LM5RIOE.
I did download firmware once. Before downloading firmware, it still worked normally. But it looks like after downloading firmware, it got problem. I am not sure, just have a doubt on it. Can u help me to check whether it has this case.
Attachements are some information on LM5RIOE.
Thank you so much.
RE: ETS do scan but did not see LM5RIOE Individual Address - Jørn - 23.10.2018
KNX Connection -> General -> set Mode to "TP-UART" , it's currently set to "EIBnet/IP Routing"
Regarding your line scan, i don't think any of the LM's show up regardless.
RE: ETS do scan but did not see LM5RIOE Individual Address - admin - 23.10.2018
Correct, LM does not appear as a physical device in ETS scan.
RE: ETS do scan but did not see LM5RIOE Individual Address - Triet Phan - 23.10.2018
Thank you , i will try it. Can you guys help to send me the link which has lastest firmware for LM5RIOE ? i can not found it in web page openrb
RE: ETS do scan but did not see LM5RIOE Individual Address - edgars - 23.10.2018
this is the correct firmware for your device:
https://dl.openrb.com/lm-18-mxs/lm5m3ex-20180828.img
