LM5 GSM VPN tunnel. - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: LM5 GSM VPN tunnel. (/showthread.php?tid=1674) |
LM5 GSM VPN tunnel. - Evens - 24.10.2018 Hi, I have a customer that have a big centralized Scada system with many locations. But they have one very remote location that they want to monitor. This location does not have any internet at this moment. I have an idea to use a LM5 Reactor GSM on the remote location, and a LM5 on one existing building that is already implemented in the Scada system. Then add a VPN tunnel between the two locations. When the data is received at the existing building, then transfer to the scada systems by Modbus TCP. Is there an easy way to do this? And if there are internet possibilities on the existing building, does the LM5 needs to be an LM5 Reactor GSM or can it be an LM5 Lite? Any good ideas? BR Even Sundgot. RE: LM5 GSM VPN tunnel. - admin - 26.10.2018 LM can run OpenVPN, but there's no UI configuration for it right now. RE: LM5 GSM VPN tunnel. - Evens - 29.10.2018 Hi Admin, Thanks for reply, OpenVPN will probably be a great solution. But how do I set it up ? Is it by script or? BR Even Sundgot. RE: LM5 GSM VPN tunnel. - MarcusH - 20.09.2019 (29.10.2018, 06:38)Evens Wrote: Hi Admin, Im wondring about this as well. Is this already in the LM or just prepeard for later ? RE: LM5 GSM VPN tunnel. - Daniel - 20.09.2019 The solution already exist but to configure it you would need access via ssh. We need to wait for some api to be able co configure it. |
