New ekey packages for ekey FSX scanners - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: New ekey packages for ekey FSX scanners (/showthread.php?tid=1681) |
New ekey packages for ekey FSX scanners - agris - 29.10.2018 Hi, here are the links to download the new ekey packages for ekey module (FSX) scanners: LM5: http://www.ekey.lv/logicmachine/luaekey_20180801_imx6.ipk http://www.ekey.lv/logicmachine/genohm-scada-ekey_20190121_imx6.ipk LM3, LM4: http://www.ekey.lv/logicmachine/luaekey_20180801_mxs.ipk http://www.ekey.lv/logicmachine/genohm-scada-ekey_20190121_mxs.ipk The app remains the same, but there are many back-end improvements on stability and functionality. New functions: 1. User can select the required RS485 port for communication to ekey scanners. As RS485 port can also be used ekey USB converter 2. Implemented database for the ekey user credentials (fingerprints, RFID cards) 3. Commands to transfer ekey user credentials (fingerprints, RFID cards) from fingerscanners to database or reverse 4. Fingerprint/RFID card enrollment, delete with following sync to all active scanners and database 5. Enabled the scanner ‘multiple enrollment” mode 6. Enrollment of new fingerprint with following sync to all active scanners and database 7. Enabled scanner “self-learning” function with following sync to all active scanners and database 8. Supported the scanner with REL functionality (can switch ekey on-board relay) 9. Supported the scanner LED lamp controls 10. Scanners must be activated using access code based on its serial number 11. System is tested with 10 scanners simultaneously connected to the single RS485 port. 12. The last full list of the known FSX type scanners are listed bellow: code ="801566", description="ekey FSX IN 2.0" code ="801582", description="ekey FSX AP 2.0" code ="802010", description="ekey FSX UP E" code ="802011", description="ekey FSX UP E REL E" code ="802012", description="ekey FSX UP E RFID E" code ="802013", description="ekey FSX UP E RFID REL E" code ="802015", description="ekey FSX UP I" code ="802017", description="ekey FSX AP 2.1 REL" code ="802018", description="ekey FSX AP 2.1 RFID REL" code ="802082", description="ekey FSX IN 2.1" code ="802084", description="ekey FSX IN 2.1 RFID" code ="802102", description="ekey FSX AP 2.1 RFID" code ="802291", description="ekey FSX UP RFID I" code ="802670", description="ekey FSX UP RFID REL" code ="802671", description="ekey FSX UP I REL" code ="802827", description="ekey FSX UP E SC" code ="802828", description="ekey FSX UP RFID E SC" code ="802836", description="ekey FSX UP I SC" code ="802838", description="ekey FSX UP RFID I SC" · the “ekey home” or “ekey net” scanners are incompatible with this application. RE: New ekey packages for ekey FSX scanners - mishoboss - 09.05.2021 Hi, unfortunately links are not working anymore. How can this version be downloaded? |
