Script - how to end script if true - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Script - how to end script if true (/showthread.php?tid=1685) |
Script - how to end script if true - Kai-Roger - 31.10.2018 Hi. I have some code that i want to stop/exit at first line if true. How is this achived in Lua? I can't find a straight answer for this on google. if VALUE1 < VALUE2 then "don't go to next if: exit, break, return or something like that" end if VALUE3 < VALUE4 then do something end RE: Script - how to end script if true - buuuudzik - 01.11.2018 You can do this on a few ways. 1) You can return before second if Code: if temp1 < temp2 then
-- do something
return -- could be with some value
if temp3 < temp4 then
-- do something
end2) You can nest your second if in the first Code: if temp1 < temp2 then
-- do something
-- do something
end3) If in the first if there is only this secondd you can combine your conditions with AND gate Code: if temp1 < temp2 and temp3 < temp4 then
-- do something
endRE: Script - how to end script if true - Kai-Roger - 01.11.2018 Thanks Nest of the second if was a great solution for my case.
RE: Script - how to end script if true - buuuudzik - 01.11.2018 I think now you will write more powerful programs
