No values read - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: No values read (/showthread.php?tid=1706) |
No values read - BMA - 08.11.2018 Hi, Im installing my first LM5 an have made a visulalization. But have problem with recieving and sending values from the KNX , no values are updated. Do i need a script for this?? Tips? RE: No values read - admin - 08.11.2018 Which firmware version do you have? RE: No values read - BMA - 08.11.2018 (08.11.2018, 18:50)admin Wrote: Which firmware version do you have? I can check tomorrow. As i remember it was testet a while ago before it was innstalled, the values got updated. RE: No values read - Erwin van der Zwart - 09.11.2018 Hi, Do you have set the KNX connection to TPUART under the system settings? BR, Erwin RE: No values read - BMA - 09.11.2018 (09.11.2018, 06:31)Erwin van der Zwart Wrote: Hi, That was wrong, so its working now!
RE: No values read - Erwin van der Zwart - 09.11.2018 Hi, Nr 1 reason, happens almost to every new customer (: @admin: Can we change this? Without KNX PSU you get question to switch to IP and everybody clicks yes, this is good but can we auto switch back to TPAURT or get question for it when PSU is detected again? BR, Erwin RE: No values read - CHOUAIBOU - 12.11.2018 (09.11.2018, 17:17)Erwin van der Zwart Wrote: Hi, Hi Erwin, May be you are wright, but first of all, a lot of people do not take time to read device's user manual. You have the same problem when LM is used as KNX interface with ETS software in the commissioning. B.R |
