Time delay by pushbutton - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Time delay by pushbutton (/showthread.php?tid=1784) |
Time delay by pushbutton - Jayce - 13.12.2018 Hello, I'm using Sentido by Basalte pushbutton, where I dim lights by using Jung DALI Gateway (Catalogue: 2099REGHE). I'm having a problem with the dimming function, where whenever I try to dim the light by longpress, there is a delay when I press the button and when I release the button. I'm not sure why there is this delay. Settings in DALI Gateway: DALI curve is set to linear, soft ON/OFF function is OFF, time delay function is also OFF. It shouldn't be caused by sentido, because when I'm not using DALI Gateway but rather some 2 channel dimmer by Jung it works nicely. Do you guys have any idea why this might be happening? The delay is around 0,3-0,4 of a second. Thank you in advance. RE: Time delay by pushbutton - Erwin van der Zwart - 13.12.2018 Hi, Isn’t this just a basic KNX device question? Check first the parameters of the sending device (Basalte) and if there is no delay set for long push then i would monitor the bus on general traffic load and check what side is causing the delay and contact the manufacturer Jung or Basalte. BR, Erwin RE: Time delay by pushbutton - Jayce - 14.12.2018 Hello, Thank you for quick response, I checked the things you said but nothing seems to solve the problem. I'll contact manufacturers as you said. Thank you for help anyway. |
