NetworX (Interlogic) Gateway - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: NetworX (Interlogic) Gateway (/showthread.php?tid=1787) |
NetworX (Interlogic) Gateway - gtsamis - 14.12.2018 Hi, I am trying to implement a LM to a NetworkX NX-8E alarm panel gateway and i need some help creating the basic serial over IP comunication script as i haven't any experience with serial protocols. If someone else has implement something relative and could help it would bu much appreciated. Networx RS-232 Gateway Interface Protocol Thank you in advance George RE: NetworX (Interlogic) Gateway - stavros.charalambous@cut.ac.cy - 18.02.2026 Any luck with this topic? RE: NetworX (Interlogic) Gateway - cgn - 19.02.2026 I've a meter with a P1 port(=serial). To read the data is use this: Code: lastchar = '!'
require('serial')
port = serial.open('/dev/ttyUSB1', {
baudrate = 115200, --DSMR 2/3 = 9600 DSMR 4 = 115200
databits = 8, --DSMR 2/3 = 7 DSMR 4 = 8
stopbits = 1, --DSMR 2/3 = 1 DSMR 4 = 1
parity = 'none', --DSMR 2/3 = even DSMR 4 = none
duplex = 'full'
function readdata(port)
local char, buf
buf = {}
while true do
char = port:read(1)
-- error (timeout) or newline, stop
if char == nil or char == lastchar then
break
-- ignore cr char
elseif char ~= '\r' then
table.insert(buf, char)
return table.concat(buf)
data = readdata(port)
port:flush()
if data then
AphA = data:match'31.7.0%((%d+.%d+)'
AphA = tonumber(AphA)
grp.update('32/1/74', AphA)
-- "more code"
end |
