Get group value without variable - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Get group value without variable (/showthread.php?tid=1792) |
Get group value without variable - Kai-Roger - 17.12.2018 Hi. I'm trying to find out how to write the code "if this then" with direct use of group value without using variables. if grp.getvalue('1/1/84') == false then do something The code above is not working BR Kai-Roger RE: Get group value without variable - Daniel - 17.12.2018 It should work only your group 1/1/84 must be a boolean RE: Get group value without variable - Kai-Roger - 17.12.2018 (17.12.2018, 11:58)Daniel. Wrote: It should work only your group 1/1/84 must be a boolean Yes you are right. Thanks (: |
