LM5Lp2 Disk: 100% - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: LM5Lp2 Disk: 100% (/showthread.php?tid=1799) |
LM5Lp2 Disk: 100% - davidsilva - 19.12.2018 Hi I have a LM5Lp2 but all changes that I try to do, disappear. In bottom bar appear one more information: Disk: 100% which usually doesn’t appear. If I try to export to another Logic Machine this information doesn’t appear. When I go to the menu System config -> Status -> System status -> Partitions, the file system “/dev/mtdblock0” is full. Why it’s happen? Best regards, RE: LM5Lp2 Disk: 100% - Daniel - 19.12.2018 Hi Try updating FW to RC1 BR RE: LM5Lp2 Disk: 100% - admin - 19.12.2018 How many trends do you have? /dev/mtdblock0 stores databases and trends. You will probably have to delete some trends to free up space for the main database. RE: LM5Lp2 Disk: 100% - davidsilva - 19.12.2018 (19.12.2018, 11:16)Daniel. Wrote: Hi Hi, This is the Version 20180822. Isn’t it the last? Best regards, (19.12.2018, 11:19)admin Wrote: How many trends do you have? /dev/mtdblock0 stores databases and trends. You will probably have to delete some trends to free up space for the main database. Hi, I only have 7 trends. On previous projects I used more and had no problems. Best regards, RE: LM5Lp2 Disk: 100% - Daniel - 19.12.2018 You probably used lower resolution. Change from 5years to 2 and you will shrink it by 3. Latest FW is RC1 20180828 RE: LM5Lp2 Disk: 100% - davidsilva - 19.12.2018 (19.12.2018, 11:54)Daniel. Wrote: You probably used lower resolution. Change from 5years to 2 and you will shrink it by 3. Latest FW is RC1 20180828 Hi, I update the FW, delete 5 trends, change the resolution from 5 years to 2, and the disk kept at 100%. After waiting 10 min, I rebooted the LM and the trends appeared again without changes. Best regards. RE: LM5Lp2 Disk: 100% - Daniel - 19.12.2018 You have to sync the project. Bottom right corner button. Just changing resolution will be fine. RE: LM5Lp2 Disk: 100% - Thomas - 19.12.2018 Hi The device with splitted drive for data is available max for 2 years. So there coulnd't be older data than two years. 12*24*365*2=210240. 4136KB/210240 = 20B per one trend row. It's 2x more than I would expected for storing decimals with zero precision. Isn't it a bug? RE: LM5Lp2 Disk: 100% - Daniel - 19.12.2018 (19.12.2018, 12:53)Thomas Wrote: Hi When you create a trend LM reserve already final size for this trend. Even empty trend once created will have final size. Otherwise we will have constant memory problems or disk size. RE: LM5Lp2 Disk: 100% - davidsilva - 19.12.2018 (19.12.2018, 12:47)Daniel. Wrote: You have to sync the project. Bottom right corner button. Just changing resolution will be fine. Hi, Previously, I had already do the Sync project data. Now I did it again and it happens again. Best regards, RE: LM5Lp2 Disk: 100% - Daniel - 19.12.2018 (19.12.2018, 14:50)davidsilva Wrote:(19.12.2018, 12:47)Daniel. Wrote: You have to sync the project. Bottom right corner button. Just changing resolution will be fine. Hi Do you mean that still 100%? If yes can you drop me your project to PM? BR |
