LM shows up under device in programming mode ETS - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: LM shows up under device in programming mode ETS (/showthread.php?tid=1800) |
LM shows up under device in programming mode ETS - espenavitell - 19.12.2018 HI I have curently installed 1 LM5 in an exsisting knx installation. The LM is located on a new backbone 0.0.0 because we needed a new area. when i connect the exsisting knx line/area to the LM, the LM shows up under device's in programmig mode. Some thoughts? i Know it's the LM because i changed the knx addresse and it still shows up under device's in programming mode with the new address. RE: LM shows up under device in programming mode ETS - Daniel - 19.12.2018 What if you connect a usb interface instead of LM ? RE: LM shows up under device in programming mode ETS - Jayce - 19.12.2018 99% I'm wrong, but I had a situation yesterday, where I pre-programmed Auro by basalte (PIR sensor), then I connected it to KNX bus but it didn't work. So I put it into programming mode and checked it's address and it showed as 15.15.255, which was the address of logic machine. As soon as I full-downloaded it, it changed to it's original address. This happend for two Auros, both of them had the same address when I put them in programming mode. No idea why, everything works now. Strange. RE: LM shows up under device in programming mode ETS - espenavitell - 19.12.2018 yeah i can try to connect with usb for settup. but i dont think that would fix the problem. RE: LM shows up under device in programming mode ETS - Krstfr2k - 21.12.2018 Disconnect the BUS line from the power supply to put all devices out of programming mode and try again. |
