Home Connect, Miele@Home - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Home Connect, Miele@Home (/showthread.php?tid=1816) |
Home Connect, Miele@Home - tomnord - 04.01.2019 Hello, anyone been succesfull in implementing kitchen appliances witch LM? I've so far found Bosch/Siemens/Neff with Home Connect (wifi) and Miele@Home (wifi), but I have not found any usefull KNX gateways. Thanks in advance. Edit: Link to API, https://www.programmableweb.com/api/home-connect-physical-appliance RE: Home Connect, Miele@Home - Erwin van der Zwart - 04.01.2019 Hi, Should be possible with LM/W4K/SL. There are multiple samples on this site that connect to a RESTful API. Look for Tesla or Netatmo to have a script that you easily can adjust. BR, Erwin RE: Home Connect, Miele@Home - andeug - 18.09.2020 I am interested in the same integration with Miele@Home, as I have Miele appliances and they are all connected to the cloud. I believe that such integration comes for the ones who are buying the hardware called Miele@home Gateway XGW3000. My appliances are connected directly to the Miele cloud through WiFi and this gateway works with ZigBee devices which are no longer being used and they are not supported by Miele, as Miele has moved to WiFi-only devices and their IoT cloud. Some discussions are on this forum. |
