KNP/TP :Connected ???? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: KNP/TP :Connected ???? (/showthread.php?tid=185) |
KNP/TP :Connected ???? - phongvucba - 10.01.2016 On LM3, the "alert" when you press the function. it appears the words "knp / TP: Connected" very much. interrupting system LM3 At the same time there is also the error log "KNX / TP Transmitter error (send 0 receive 1)" how to remove "KNX / TP connected" in the alert. ?? interrupting system LM3 thank all! RE: KNP/TP :Connected ???? - admin - 11.01.2016 KNX/TP might be overloaded, if you have several LMs on a single KNX/TP line they might cause a telegram loop. If this happens then "KNX/IP features" must be disabled in all but one LM. Otherwise, if KNX/TP is not overloaded, send us your LM for replacement. Please contact us by e-mail for further actions. |
