Send LM object value to the KNX bus every hour - Printable Version
+--- Thread: Send LM object value to the KNX bus every hour (/showthread.php?tid=1878)
Send LM object value to the KNX bus every hour - Kai-Roger - 30.01.2019
Hi.
I have 18 temperature object values in LM that i want to send to the KNX bus every hour (to update touchpanels). What's the best way to do this ? Do i have to set up a resident script with 60 min sleep? In that case, does anyone know how this code should be written?
Kai-Roger
RE: Send LM object value to the KNX bus every hour - admin - 30.01.2019
You should use a scheduled script for such large intervals. You can tag all objects that needs re-send action and use this script:
objects = grp.tag('resend') for _, object in ipairs(objects) do   grp.write(object.address, object.value)   sleep(0.1) end
RE: Send LM object value to the KNX bus every hour - Kai-Roger - 30.01.2019
(30.01.2019, 12:00)admin Wrote: You should use a scheduled script for such large intervals. You can tag all objects that needs re-send action and use this script:
Thanks (:
