Wildcard for activation of scripts - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Wildcard for activation of scripts (/showthread.php?tid=19) |
Wildcard for activation of scripts - RSV4 - 06.07.2015 Hi all, I am using a lot of little scripts for presence simulation. Up to now I have to manually activate all those scripts before I go on holiday. Alternatively I could write a script as follows to enable all simulation scripts, but that would mean typing in approx. 100 lines manually. Code: script.enable('Simulation 1: Entrance on')
script.enalbe('Simulation 1: Office on')
...Since all the scripts start with the word "Simulation": Is it possible to use a wildcard to enable/disable all scripts that start with "Simulation", something like Code: script.enable('Simulation*')? Many thanks and best regards RSV4 RE: Wildcard for activation of scripts - edgars - 06.07.2015 thanks for a suggestion! There is such thing as Category in Scripts. In the upcoming firmware we will implement enable/disable of Category which will relieve plenty of code
RE: Wildcard for activation of scripts - RSV4 - 06.07.2015 Hi Edgars Many thanks for your quick reply, therefore I will wait for the new firmware. Any plan for the release date? Great idea with the forum! Many thanks RSV4 RE: Wildcard for activation of scripts - rocfusion - 06.07.2015 Hi, In the meantime you could create a table of the script names and then parse the table with loop to enable\disable them. Code: local myscripts = {"script a","script b","Event for 12/0/1"}
function enablescripts()
for i in pairs(myscripts) do
script.enable(myscripts[i])
function disablescripts()
script.disable(myscripts[i])
-- to disable
disablescripts()
-- to enable
enablescripts()Thanks, Roger RE: Wildcard for activation of scripts - edgars - 06.07.2015 Hi Robin, we expect it this/next week. RE: Wildcard for activation of scripts - RSV4 - 06.07.2015 Hi Roger, thank you for the code. This unfortunately would also mean typing in all the script names and having to update them manually as soon as I add/remove a script from my simulation. Since it is only a week or two wait, the new firmware will be available before my next holidays :-) @Edgars: Wow, did not expect it that soon, great! Best regards, Robin RE: Wildcard for activation of scripts - Erwin van der Zwart - 10.07.2015 You don't need to type the scripname (or other) manualy, just select them in the pulldown box from the panel on the right side of your script. RE: Wildcard for activation of scripts - RSV4 - 20.07.2015 Have not tried that yet, thank you. But that will still require to maintain the array of names manually when I add/delete scripts. RE: Wildcard for activation of scripts - RSV4 - 10.08.2015 (06.07.2015, 12:32)edgars Wrote: thanks for a suggestion! Hi Edgars Is this implemented in the just released beta firmware 2015.08.07? If yes, what's the lua code to enable/disalbe a script category? Best regards, Robin RE: Wildcard for activation of scripts - edgars - 11.08.2015 Hey Robin! Try the following functions: Code: script.categoryenable(category)Code: script.categorydisable(category)RE: Wildcard for activation of scripts - RSV4 - 11.08.2015 Hi Edgars! I've tried script.category.enable, script.enable(category) and a lot of others but did not come up with 'categoryenable' in one word Could you include these two commands in the script code examples in the new firmware? I did not see them in the beta version. Thanks a lot! BTW: Is there a complete list of all LM script commands available, meaning everything 'outside' the standard lua language such as the commands above? Best regards, Robin RE: Wildcard for activation of scripts - Pawel - 11.08.2015 Quote:BTW: Is there a complete list of all LM script commands available, meaning everything 'outside' the standard lua language such as the commands above?That would be grate
RE: Wildcard for activation of scripts - RSV4 - 11.08.2015 Hi Edgars I have no success with the follwing code: Code: -- activate/deactivate all scripts for presence simulation
-- get value that triggered this script
evval = event.getvalue()
-- activate/deactivate scripts
if evval == true then
script.categoryenable('Simulation')
script.categorydisable('Simulation')
endScripts with the category "Simulation" do not change their status at all, even on shift-refreshing the browser. The "Active" bulb stays the way it was. Any hints? Best regards, Robin RE: Wildcard for activation of scripts - admin - 12.08.2015 We'll do some tests soon and will let you know of the results. RE: Wildcard for activation of scripts - RSV4 - 31.08.2015 Hi all, is there any news on this one? Best regards, Robin RE: Wildcard for activation of scripts - admin - 31.08.2015 Yes, it should work in new release. We will be releasing new batch of firmwares soon, stay tuned
RE: Wildcard for activation of scripts - RSV4 - 31.08.2015 Great, thank you! RE: Wildcard for activation of scripts - RSV4 - 31.08.2015 Works like a charm with the firmware you released later this day (tested on LM3:Reactor)! You guys are great, thank you so much! For readers of this thread: My script above works if you like to use it as well. |
