If all "tag" objects are false, then - Printable Version
+--- Thread: If all "tag" objects are false, then (/showthread.php?tid=1981)
If all "tag" objects are false, then - Kai-Roger - 18.03.2019
Hi.
Is there a script that can do something if all objects with a certain tag is false?
Kai-Roger
RE: If all "tag" objects are false, then - Erwin van der Zwart - 18.03.2019
Try this:
tagname = 'tag name' for _, obj in ipairs(grp.tag(tagname)) do  if obj.value then    return  end end log('All objects are false')
RE: If all "tag" objects are false, then - Kai-Roger - 18.03.2019
(18.03.2019, 22:03)Erwin van der Zwart Wrote: Hi,
Try this:
Hi.
Thanks a lot!
With a lot of trial and error, i finaly got this to do what i want. If all tags are false, then Lights_status is false. If one or more of the tags are true, then Lights_status are true :)
tagname = 'Lights_room1'
Lights_status = grp.find('1/1/137')
  if obj.value then
    return
      Lights_status:write(true)
     Lights_status:write(false)
And here a little more adjusted to suite my purpose better in a bigger script, and to work with only tag's (no group adresses) :)
for _, obj in ipairs(grp.tag('Lights_room1')) do
  if obj.value then
    return
    grp.tag('All_lights'):write(true)
grp.tag('All_lights'):write(false)
RE: If all "tag" objects are false, then - Erwin van der Zwart - 19.03.2019
Are you sure your script works?
I would expect the command in true state before the return..
RE: If all "tag" objects are false, then - Kai-Roger - 19.03.2019
(19.03.2019, 05:39)Erwin van der Zwart Wrote: Hi,
Hi. Yes it does what i expected.
Here is how it responds:
But what i failed to do, was to use two of these codes after another in the same code. I think it stops at the first one, so i have to change something so that the scripts run every part of the code.
RE: If all "tag" objects are false, then - Krstfr2k - 20.03.2019
Not the prettiest script but atleast it works  Angel
tag = grp.tag('lights_1') lights_on = 0 -- arraytable = { 'a', 'b', 'c' } for i, value in ipairs(tag) do  local lights_status = grp.getvalue(value.address)  if lights_status == true then    lights_on = lights_on + 1  end end if lights_on == 0 then  log('All lights off') else  log('Some lights are on') end
RE: If all "tag" objects are false, then - admin - 20.03.2019
You don't need grp.getvalue there, each object table already has value field populated.
