Dew Point - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Dew Point (/showthread.php?tid=1990) |
Dew Point - Allesreinwasgeht - 26.03.2019 Hi There, this will be my first post. I cant find a solution for a dew point calculation by using homelync. my system is collecting inside and outside humidity plus inside and outside temp. all in 0-255 coming from an analog input. so dont bother about units. 1/15/1 Hum.i (0-255) 1/15/2 Temp.i (0-255) 1/15/11 Hum.o (0-255) 1/15/12 Temp.o (0-255) the aim is to start vents in case of a good result (max drying) only. the trigger is the dewpoint of air coming from outside. 1/3/1 Vent.start (1Bit) maybe there is a workaround. best (as you can see, my native language is german
RE: Dew Point - admin - 26.03.2019 Dew point calculation: Code: hum = 60 -- 0..100% range
temp = 10 -- temperature in deg C
dew = ((hum / 100) ^ (1 / 8)) * (112 + (0.9 * temp)) + 0.1 * temp - 112
log(dew)RE: Dew Point - Allesreinwasgeht - 26.03.2019 (26.03.2019, 10:33)admin Wrote: Dew point calculation: Thanx. whats the log(dew) for? best RE: Dew Point - admin - 26.03.2019 This way you can see variable contents in Logs tab: http://openrb.com/docs/lua.htm#log RE: Dew Point - Allesreinwasgeht - 26.03.2019 (26.03.2019, 14:35)admin Wrote: This way you can see variable contents in Logs tab: http://openrb.com/docs/lua.htm#log THX |
