See kwh each month - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: See kwh each month (/showthread.php?tid=1993) |
See kwh each month - Kai-Roger - 28.03.2019 Hi. I have an object that counts continous kWh for a hot water tank, but it don't tell me the consumption in what month or year. What is the best way to capture the consumption like 24:00 a clock the last day each month? Is there altso a good way to show this graphically like in the attached picture? In this picture it shows the last 2 years. BR Kai-Roger RE: See kwh each month - admin - 28.03.2019 Use trends. Yearly view is a bar chart as you need. RE: See kwh each month - Kai-Roger - 28.03.2019 (28.03.2019, 16:56)admin Wrote: Use trends. Yearly view is a bar chart as you need. Something like this? Counter. What about aggregate function? RE: See kwh each month - Daniel - 28.03.2019 This is correct but it is safer to use counter with negative data in case your value might go down in some point in the feature. With solar panels it is possible. Use average. RE: See kwh each month - Kai-Roger - 28.03.2019 (28.03.2019, 17:16)Daniel. Wrote: This is correct but it is safer to use counter with negative data in case your value might go down in some point in the feature. With solar panels it is possible. Use average. Smart with negative data! But will this setup show the exact kwh consumption each month in this view? RE: See kwh each month - Daniel - 28.03.2019 Yes this is what it was designed for
RE: See kwh each month - Kai-Roger - 28.03.2019 (28.03.2019, 17:26)Daniel. Wrote: Yes this is what it was designed for Thanks
