MQTT publish json - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: MQTT publish json (/showthread.php?tid=2008) |
MQTT publish json - JohnTH - 05.04.2019 Hi, I am using admin`s mqtt script from this post: https://forum.logicmachine.net/showthread.php?tid=1759 Is there a way to change this: object_to_mqtt = { ['1/1/1'] = 'out/topic1', ['1/1/2'] = 'out/topic2', } to send a variable that is a json string with multiple values (something like this): valueX= grp.getvalue('32/3/1') valueY= grp.getvalue('32/3/2') topic1 = '{"site": "building", "equipment":"ventilation3601", "current_mode":"'..valueX..'", "current_status":"'..valueY..'"}' object_to_mqtt = { [topic1] = 'out/topic1', ['1/1/2'] = 'out/topic2', } -John RE: MQTT publish json - admin - 08.04.2019 Do you only need to publish states or do you need two-way communication? RE: MQTT publish json - JohnTH - 08.04.2019 (08.04.2019, 09:50)admin Wrote: Do you only need to publish states or do you need two-way communication? It would be nice to have publish and subscribe in the same scipt, but I already have another working script for subscription so not a must. John RE: MQTT publish json - admin - 09.04.2019 You can use event script to publish and disconnect after publish, like in this post: https://forum.logicmachine.net/showthread.php?tid=1793 Use json.encode to create your data string instead of creating JSON string manually. This code will publish once connected and disconnect once publish is done. Code: client.ON_CONNECT = function(stat, code, err)
if stat then
client:publish('devices/' .. device_id .. '/messages/events/', data)
log('mqtt connect error', err, code)
client.ON_PUBLISH = function()
client:disconnect()
running = false
endRE: MQTT publish json - JohnTH - 09.04.2019 (09.04.2019, 07:16)admin Wrote: You can use event script to publish and disconnect after publish, like in this post: https://forum.logicmachine.net/showthread.php?tid=1793 Thanks! I will give it a try. |
