json.encode not working correctly - Printable Version
+--- Thread: json.encode not working correctly (/showthread.php?tid=2050)
json.encode not working correctly - usyntax - 26.04.2019
How i can use json.encode() function? I tried use this script:
test = {   one='first',two='second',three={2,3,5} } jsonTest = json.encode(test)
but i get error:
attempt to index global 'json' (a nil value) stack traceback: User script:37: in main chunk
RE: json.encode not working correctly - admin - 26.04.2019
You are probably missing require('json') at the beginning of your script.
