Switching from FT to LoRa - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: CANx (https://forum.logicmachine.net/forumdisplay.php?fid=23) +--- Thread: Switching from FT to LoRa (/showthread.php?tid=2055) |
Switching from FT to LoRa - Kai-Roger - 29.04.2019 Hi. If i disconnect the FT connector from a device, how long time will it take for the LoRa to take over the communication? Instantaneously? BR Kai-Roger RE: Switching from FT to LoRa - admin - 29.04.2019 There's no delay. RE: Switching from FT to LoRa - Kai-Roger - 29.04.2019 (29.04.2019, 07:44)admin Wrote: There's no delay. So it is theoretically not possible to lose a telegram if the connector is disconnected at just the right time? RE: Switching from FT to LoRa - admin - 29.04.2019 The system is meant to work either with wired OR wireless connection, not both together for the same network segment. RE: Switching from FT to LoRa - Kai-Roger - 29.04.2019 (29.04.2019, 09:18)admin Wrote: The system is meant to work either with wired OR wireless connection, not both together for the same network segment. Hi. Daniel wrote in a earlier post that the system will work as redundant. When wire is disconnected, the wireless takes over. I have tested this, and it works like Daniel wrote. I'm just wondering how long time the wireless uses to establish connection when wire gets disconnected. I see that this wireless redundant function is extremely fast
