Right object type for Track Next/Previous - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Right object type for Track Next/Previous (/showthread.php?tid=207) |
Right object type for Track Next/Previous - managementboy - 03.02.2016 I am having trouble deciding how to implement a Next Track .. Previous Track for my sound system as objects. Should I use two separate objects? RE: Right object type for Track Next/Previous - admin - 03.02.2016 Our KNX control for streaming player uses single object - 0 (false) for previous track, 1 (true) for next track RE: Right object type for Track Next/Previous - managementboy - 05.02.2016 (03.02.2016, 16:10)admin Wrote: Our KNX control for streaming player uses single object - 0 (false) for previous track, 1 (true) for next track thanks, probably I did not state my problem correctly. In the touch visualisation: what kind of "button" would give me the traditional look of next/previous. The problem with true/false is that if I want to jump next,next,next the object switches true,false,true. RE: Right object type for Track Next/Previous - edgars - 05.02.2016 Hi Elkin! use Send Fixed Value = 1 parameter when adding Binary object on the visualization - this will be used as NEXT button. Similar for PREVIOUS button. RE: Right object type for Track Next/Previous - managementboy - 09.02.2016 (05.02.2016, 12:48)edgars Wrote: Hi Elkin! thanks!!! |
