Change of color in Visu - Printable Version
+--- Thread: Change of color in Visu (/showthread.php?tid=2075)
Change of color in Visu - Tokatubs - 08.05.2019
When i draw in the Visualization its in white. But when i load visualization it goes black.
Is there any setting to keep it white?
RE: Change of color in Visu - admin - 09.05.2019
This is because you have "Use dark theme" enabled in Vis. configuration.
RE: Change of color in Visu - Tokatubs - 09.05.2019
(09.05.2019, 06:12)admin Wrote: This is because you have "Use dark theme" enabled in Vis. configuration.
A could not find that setting at first. Thanks. Is there any possibility to have a front page on the mosaic, much like this in the picture. ?
RE: Change of color in Visu - Daniel - 14.05.2019
This was just image made by graphical designer, in reality this is not possible. You can add to home screen selected widgets but not exactly this image.
