Logic Machine Forum
strange group address broadcast on LM? - Printable Version
+--- Thread: strange group address broadcast on LM? (/showthread.php?tid=2101)
Pages: 1 2
RE: strange group address broadcast on LM? - gtsamis - 14.06.2019
(13.06.2019, 15:51)puntukas Wrote: Daniel: yes, sending two telegrams to different group address. Nothing connected to address in trouble.
GTSAMIS: tokka EVO096.
Thanks everyone!
I have no experience with the specific gateway, in my case i had to erase and reprogram the gateway and solve my problem
RE: strange group address broadcast on LM? - puntukas - 14.06.2019
Thanks everyone!
I did it. Nothing changes. As LM restarts - it generates these telegrams, so I think the reason is somewhere in LM Sad
RE: strange group address broadcast on LM? - Erwin van der Zwart - 14.06.2019
As sender is “bus” that is not possible in my opinion..
If you are so sure it comes from the controller then you need to check objects if read during startup is checked or if read interval is > 0 and check your scripts and startup script and custom JS (JS can only run when a client is active). Check if any tag is linked to the object that you might have overlooked.
There is no way the controller does this on its own without any cause activated from items above...
Can you disable KNX IP features on the reboot to be sure it does not come from IP somewhere?
RE: strange group address broadcast on LM? - puntukas - 21.06.2019
Thanks, Erwin!
I disabled KNXIP on LM, rebooted and telegrams did not showed up. When I enabled and rebooted - two telegrams generated.
If it comes from other device - why telegrams are generated after reboot? I even deleted 3 startup lines - the same: 2 telegrams generated.
Thanks...
RE: strange group address broadcast on LM? - Daniel - 24.06.2019
Send me your backup to PM. I will check if it happens on my network too. If yes then it is LM problem if not, your installation somewhere else.
RE: strange group address broadcast on LM? - iJAF - 06.07.2023
Was this case solved ?
What was the solution for this issues ?
RE: strange group address broadcast on LM? - Daniel - 06.07.2023
You wouldn't expect us to remember this after 4 years.
