[?] random alert via mail - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: [?] random alert via mail (/showthread.php?tid=2125) |
[?] random alert via mail - Allesreinwasgeht - 24.06.2019 HI sceneario: one of the group adresses formated as 1.005 is giving 'alert' problem: send goup adress(es) via mail. question: is there any posible fitler integrated apart form a huge script? (Mailing part is solved) RE: [?] random alert via mail - Daniel - 24.06.2019 Hi Can you explain what filter do you want? BR RE: [?] random alert via mail - admin - 24.06.2019 The easiest way to send multiple group address values is to assign a tag. This example will output one name = value pair per line for all objects with alert tag: Code: values = {}
objects = grp.tag('alert')
for _, obj in ipairs(objects) do
value = string.format('%s = %s', tostring(obj.name), tostring(obj.value))
values[ #values + 1 ] = value
result = table.concat(values, '\r\n')
log(result)RE: [?] random alert via mail - Allesreinwasgeht - 24.06.2019 (24.06.2019, 08:24)admin Wrote: The easiest way to send multiple group address values is to assign a tag.THX! its close to my target. I didnt want need to tagging before, but its fine. My aim was to filter groups in format 1.005 set to 'true' to create a alert mail including all alerts in case of alarts only. Best |
