Mosaic 3.0: Json widget creation - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Mosaic 3.0: Json widget creation (/showthread.php?tid=2171) |
Mosaic 3.0: Json widget creation - Domoticatorino - 25.07.2019 Dear all, I try to surf on the forum without success. I would like to create my own Mosaic widget with a json file but I have a sample. Could you share a sample or a guide to create and customised widget with json file? Thanks. RE: Mosaic 3.0: Json widget creation - Daniel - 26.07.2019 Hi Here is documentation how to make widget https://openrb.com/wp-content/uploads/2016/11/Mosaic_widgets_eng.pdf If this does not scare you I can send you example widget. It is much easier to us widget creator. BR RE: Mosaic 3.0: Json widget creation - Domoticatorino - 26.07.2019 Hi Daniel, please find an exmple widget. Thanks. RE: Mosaic 3.0: Json widget creation - Zen - 28.08.2023 (26.07.2019, 08:32)Daniel Wrote: Hi Hi Daniel, is there any link available today to any guide for JSON widget creation? This link you posted, seems to be unavailable. Thank you. RE: Mosaic 3.0: Json widget creation - admin - 28.08.2023 JSON is used for custom widgets which are created in the UI. User-created Mosaic widgets are JavaScript/CSS not JSON. Making such widgets is not a trivial task and you won't be able to use such widgets in LM cloud, only locally. RE: Mosaic 3.0: Json widget creation - Zen - 29.08.2023 (28.08.2023, 08:21)admin Wrote: JSON is used for custom widgets which are created in the UI. User-created Mosaic widgets are JavaScript/CSS not JSON. Making such widgets is not a trivial task and you won't be able to use such widgets in LM cloud, only locally. Yes sorry, finally i've read the manual about it. Thanks |
