Write/Read KNX IP Interface - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Write/Read KNX IP Interface (/showthread.php?tid=2188) |
Write/Read KNX IP Interface - Krstfr2k - 07.08.2019 Hello, I was wondering if it is possible to write/read information directly from 1 or more KNX IP Interfaces that are placed in seperate installations but the same network, by using a script in LM? RE: Write/Read KNX IP Interface - Daniel - 07.08.2019 LM can tunnel to 1 interface but the downsize is that it will use only this interface. It is much better to use IP router so you can talk to it via multicast. |
