I cannot import all the addresses to the LM - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: I cannot import all the addresses to the LM (/showthread.php?tid=2212) |
I cannot import all the addresses to the LM - Josema - 29.08.2019 Good Morning I have modified my ETS project and I cannot import all the addresses to the LM, I have tried importing as an ESF file and as a JSON file, should I reset the LM? Can I delete the group addresses in some way to import them again? Br RE: I cannot import all the addresses to the LM - admin - 29.08.2019 What error are you getting? You can press "Clear" in the bottom of the Objects tab to delete all current objects. RE: I cannot import all the addresses to the LM - Josema - 29.08.2019 (29.08.2019, 05:59)admin Wrote: What error are you getting? You can press "Clear" in the bottom of the Objects tab to delete all current objects. Thank you very much, I HAVE DELETED THE OBJECTS AND WHEN IMPORTING THE NEW PROJECT I HAVE IMPORTED ALL THE ADDRESSES |
