Problems with Script Contact Window - Protection Mode - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Problems with Script Contact Window - Protection Mode (/showthread.php?tid=2294) |
Problems with Script Contact Window - Protection Mode - josemabera - 21.10.2019 Good morning: I made a script so that when a window of a room is opened, the thermostat goes into protection mode. Once the summer is over, when the heating is switched on and the system is in heating mode the thermostat is put in protection mode even when all the windows are closed, I have no remote connection to the installation but I imagine that the problem is that since LM does not perform the Change from cooling mode to heating mode, any suggestions? The script is as follows local ModoCalefaccion = grp.getvalue ("0/1/0") local ModoTermostato = "6/7/1" local tagname = 'ContatosVentanacocinasaloncomedor' if ModoCalefaccion then for _, obj in ipairs(grp.tag(tagname)) do --lee todos los objetos si se cumple la condicion (ventana abierta) pone el termostato en modo proteccion --si una vez leidos todos no se ha cumplido la condicion escribe en el modo false if obj.value then --Al menos una ventana esta abierta grp.checkwrite(ModoTermostato ,true) return end end grp.checkwrite(ModoTermostato,false) -- Todas las ventanas estan cerrada end RE: Problems with Script Contact Window - Protection Mode - Daniel - 21.10.2019 Don't you miss else before grp.checkwrite(ModoTermostato,false) ? RE: Problems with Script Contact Window - Protection Mode - josemabera - 21.10.2019 (21.10.2019, 08:20)Daniel. Wrote: Don't you miss else before Thank you Daniel for your response, tomorrow I will verify locally if the Script has it with "else" or as I wrote it in the post Thank you so much Regards RE: Problems with Script Contact Window - Protection Mode - josemabera - 22.10.2019 (21.10.2019, 08:20)Daniel. Wrote: Don't you miss else beforeChecking the script I see ,the return causes it to exit the function so if the first one is fulfilled it does not reach the second (21.10.2019, 08:20)Daniel. Wrote: Don't you miss else beforeChecking the script , the return causes it to exit the function, so if the first one is fulfilled it does not reach the second. The error was in a TAG that should not be applied in the D.G."0/1/0" Thank you B.R. |
