LED strip DMX - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: LED strip DMX (/showthread.php?tid=2298) |
LED strip DMX - rogerabit - 22.10.2019 Hi, I need programing a dmx driver with a white LED strip. I need the LED strip to light diode to diode and past some seconds go to turn off diode to diode. I have a LM Lite 5, a white LED strip and this DMX driver (https://www.amazon.es/gp/product/B00Q1N1GZS/ref=ppx_yo_dt_b_asin_image_o00_s00?ie=UTF8&psc=1) I need make somethin like this (https://youtu.be/2GBWmYc__aM?t=13) Thanks RE: LED strip DMX - admin - 23.10.2019 Do you have only one DMX driver? If so then this won't work because it can only control 3 separate channels. If you want an animated LEDs you need WS2811 or similar LED strip and a controller suitable for this type of LEDs. RE: LED strip DMX - rogerabit - 23.10.2019 Yes, I have only one DMX driver. But the LED strip is only white color, not RGB. I need other DMX driver too? RE: LED strip DMX - admin - 23.10.2019 The only thing you can do with a 3 channel dimmer is control 3 separate strips. But you can only dim the whole strip at once not separate LEDs. |
