Javascript, use value of the main knx object and display a icon - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Javascript, use value of the main knx object and display a icon (/showthread.php?tid=2311) |
Javascript, use value of the main knx object and display a icon - equalizer - 30.10.2019 Greetings. Im have a bit wise encoded knx objects (lots). I would like to bitmask part out and animate a icon via the remaining part but have become stuck at the point of selecting the icons attached. Is it possible to select what icon is displayed (from a normal animated icon), eg if "faults" value = 0 show one icon 1 to 5 show a diffecent icon, >5 show another? Or an I going down a dead end here and just create/calculate numeric ranges in the icon animation. Baised from the "Group Address value in SVG icon" example $(function(){ $('.faultIcon').each(function(i, el) { var $el = $(el), addr = $el.data('object'); // or 'status-object' grp.listen(addr, function(obj) { var faults = obj.value & 3F000000; faults = faults >> 24; ?????????? }); }); }); Robert. RE: Javascript, use value of the main knx object and display a icon - admin - 31.10.2019 You can use "Additional icons" to assign specific value to an icon. I suggest using virtual objects to display fault status values instead of Custom JS. RE: Javascript, use value of the main knx object and display a icon - equalizer - 31.10.2019 I made a script spawn the hundereds of virtual group addresses in the end. I guess the question is can custom JS "intercept" the knx value and process it before the browser selects what icon to display from the Aditional icons list? RE: Javascript, use value of the main knx object and display a icon - admin - 31.10.2019 Another approach is to use image element, attach object listeners in Custom JS and change img src depending on the value. RE: Javascript, use value of the main knx object and display a icon - equalizer - 05.11.2019 (31.10.2019, 14:24)admin Wrote: Another approach is to use image element, attach object listeners in Custom JS and change img src depending on the value.Is that using a .lp file and creating a canvas to display the icon? I started digging into that aproach and it started to get a little complex even with the image url paths hard coded :-) I may have another look at that though as I didnt know about the object listener aproch I was also trying to make a custom basic client server via url parmiters data link happen... RE: Javascript, use value of the main knx object and display a icon - admin - 06.11.2019 You don't need .lp files for that. Go to Scripting > Tools > Edit custom JavaScript. Here's an example of changing image based on value: https://forum.logicmachine.net/showthread.php?tid=2253&pid=14121#pid14121 |
